Author Topic: Code generation produces bug in template classes  (Read 2629 times)
Otter
  • Love it!
« on: November 05, 2008, 09:26:44 pm »
Hey
I am working on a project utilizing template classes. When performing code generation on the code base not all templates for the classes are shown in the created diagram.
It can be seen that all templates are created when the code generation is ongoing, but when the analysis is finished some of the templates are removed and some partly since half a name still exist.
Seems that a buffer is to short or the EA code template for classes is wrong.
Is there anyone who have found a fix for this?
Keep the Light!
Re: Code generation produces bug in template class
« Reply #1 on: November 06, 2008, 05:39:39 am »
No, but it sounds pretty serious.
First thing to check is the EA build number (the third component of the EA version in the About dialog). If you are using a build earlier than 833 you might try updating to see if the problem has been solved. [You might want to check the release notes on the EA History page first.]
If the problem is still there, file a bug report right away. You'll find the correct link near the bottom of any forum page.
