Author Topic: RTF Template - Element filtering  (Read 5832 times)
cem
« on: November 06, 2008, 08:06:53 am »
How could I filter the elements based on element's stereotype while document generation? I mean, how could I define that only the elements having stereotypeX and stereotypeY shall be included in the result document? The question may be reproduced for tagged values: How to include/exclude elements having taggedValueX = some_value?
Thank you...
Re: RTF Template - Element filtering
« Reply #1 on: November 06, 2008, 08:29:37 am »
Not in the current build.  The current plan is that it will be included in the next build.  If not then, it will be in the next major version.
cem
« Reply #2 on: November 06, 2008, 09:31:30 am »
I'll be waiting.
Thank you...
philipp.k
« Reply #3 on: June 11, 2024, 10:22:48 pm »
Hi together,
this was 2008...
Now, in 2024, I have the same question:
Can I configure some elements to be sorted out by tagged value during documentation generation?
Greetings, Philipp
« Reply #4 on: June 11, 2024, 10:57:48 pm »
That is possible yes. In Elemnet Filters of your template you can specify which elements to select.
philipp.k
« Reply #5 on: June 11, 2024, 11:36:02 pm »
Thx Geert,
I can confirm:
- in "Document Options" of the template
- for "Active Filter Set" choose "TagValue"
- check mark both "Property" and "Value" and write which TaggedValue you want to look in (in Property) and which value it should have (in Value)
- and it works!
Great!
