Author Topic: RTF:  Navigation through folders  (Read 22061 times)
..David..
« on: November 11, 2008, 08:05:11 pm »
Good Morning,.
How is it possible to navigate through the layers of folders and display the content of the folders in the RTF-Document?
Example of my structur:
Model
  -  Folder 1
       -  Item 1
       -  Item 2
       -  Item 3
  -  Folder 2
       -  Item 1
       -  Item 2
       -  Item 3
  -  Folder 3
       -  Item 1
       -  Folder 3.1
            -  Item 3.1.1
            -  Item 3.1.2
            -  Item 3.1.3
       -  Item 2
       -  Item 3
How is it possible to display all the items?
If I start the RTF Generator for the Model it first should display the Items of the Folder 1 with the headline of Folder 1 and then in this way for the others.
Maybe this is to complicate for explaining in this forum. - So is there any literatur about this topic? In the User-Guid i couldn´t get information.
Best wishs
Oliver F.
    • Karl Storz homepage
Re: RTF:  Navigation through folders
« Reply #1 on: November 12, 2008, 04:07:03 am »
Not sure whether I got the problem right but maybe this link is of use for you:
http://www.sparxsystems.com/downloads/whitepapers/Working_with_the_RTF_generator.pdf
Basically the generator steps through the model and fills the RTF with all elements which are mentioned in the template- packages, elements, etc.
So I suspect if it only exports folders you either have a template which does not fill elements or have enabled only packages in the template options.
Either way the document should help you here.
Oliver
