Author Topic: Sequence of attributes  (Read 3283 times)
Roger A. Shepherd
« on: November 20, 2008, 07:22:08 pm »
When I opened the logical diagrams today, all attributes of all classes show up in alphabetic sequence. How do I get the old settings back? I always try to put the most important and significant attributes on the top. How did this happen?
Re: Sequence of attributes
« Reply #1 on: November 20, 2008, 10:39:38 pm »
It sounds like your options got reset to their defaults. Perhaps there was a bad registry setting and EA built a new set. Who knows?
Here's a guess, but it might do the trick...
Open Tools | Options | Objects dialog. Take a look at the settings at the bottom of the left column and near the bottom of the right column. If some of these are checked you could end up with the situation you describe. Try clearing them and things might improve.
Roger A. Shepherd
« Reply #2 on: November 20, 2008, 11:01:29 pm »
Thanks. Changing that setting did the job. The original sequence is back.
