Author Topic: How to get Actors from UsesCase  (Read 3271 times)
Gustavo Rocha
« on: July 24, 2008, 04:41:23 am »
I wanna generate RTF files just getting de actors from an specific usecase. How can I do that?
Which element should I get?
Gustavo.
Krzysztof Swiatkowski
  • Understanding is a three-edged sword
Re: How to get Actors from UsesCase
« Reply #1 on: July 24, 2008, 10:19:33 am »
I am not quite sure where you are going and what you want to document but you might create a package with a diagram with that usecase and its actors - they can be dragged from elsewhere.
Then create a document template that only documents elements from the diagram (Package/Diagram/Element) and set document template element type filter to an actor. Read the docs on what gets documented and how using this method.
If that is enough than you have a solution. If its not than most likely you will have to create an external documentation plugin. Filtering of elements in EA is very simple and many things simply cannot be done with built in tools.
Regards
Kris
If I put you finger in the eye
then you have finger in the eye
and I have finger in the eye
but it's not the same
