Author Topic: EA 7.1 Build 834. XSD Feature that Uses Int Editor  (Read 3110 times)
salayande
  • I love YaBB 1 Gold!
« on: December 07, 2008, 07:29:11 am »
Dear all,
Under General Improvements :
Modified viewing XML Schemas to use XML editor specified in the options.
Cannot find where this may be set. I generated a test schema and selected the "View" and anticipated the internal editor will display the XSD but I waited to nothing happened.
Given that this is a new release, I must be missing something.
I appreciate any help on this. Thank you.
Segun
Re: EA 7.1 Build 834. XSD Feature that Uses Int Ed
« Reply #1 on: December 08, 2008, 07:58:58 am »
The option for the editor to open is at Tools | Options | XML Specifications.
If you don't specify one, EA will use the default open command for XML documents on your computer.
