Author Topic: Checkout Update element and CheckIn in C#  (Read 3342 times)
ashwinib
« on: July 23, 2008, 07:09:05 pm »
hi,
I am trying to update taggedValues of the element in my addin.
if element is under version control, I checkout the corresponding package , update the taggedValue and then checkin the package.
pkgToCheckout.VersionControlCheckout("CheckOut By Addin ");
//Update code which works fine if file is already checked out
pkgToCheckout.VersionControlCheckin("CheckedIn By Addin on ");
Problems
1. But element is not getting updated.
2. each time it displays the checkin confirmation dialog box. how do i suppress it
Please reply.
Thanks & Regards,
Ashwini
Re: Checkout Update element and CheckIn in C#
« Reply #1 on: July 25, 2008, 08:31:03 am »
Just to clarify, is the check-in dialog from your version control (SCC)provider or EA itself?
If it's from an SCC version control provider then it's either a case of configuration, or you just can't do it.
If it's EA's dialog, then I don't think it should be coming up, and this should be sent directly to sparx systems.
