Author Topic: Best DBMS Server Repository  (Read 4676 times)
Dorian Workman
« on: December 16, 2008, 06:37:18 pm »
I am setting up EA to use a DBMS Server for the first time, and would appreciate advice on the best database to use.  I see EA's Help says that MySQL has some limitations.  Is Oracle the best then?
Thanks.
<a href="http://www.linkedin.com/in/dorianworkman" ><img src="http://www.linkedin.com/img/webpromo/btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Dorian Workman
Re: Best DBMS Server Repository
« Reply #1 on: December 17, 2008, 08:28:26 am »
I've found the topic you're referring to.  (http://www.sparxsystems.com/uml_tool_guide/uml_model_management/modelmanagementdiscussion.html).
1. This details a limitation of one type of MySQL repository, but it won't change the way EA works for you.
2. I believe this is out of date, and that there are no limitations on search under MySQL.  I will see that this gets changed.  (Although I am aware of an issue with searches under Oracle)
3&4. Not a limitation, just a minimum version.  There are version restrictions on all databases that EA supports.
In our testing, MySQL repositories achieved the best performance over slower networks.
« Last Edit: December 17, 2008, 08:29:17 am by simonm »
Dorian Workman
« Reply #2 on: December 17, 2008, 09:14:02 am »
Thanks Simon, sorry I should have quoted that link myself.
Actually, I've just realized that I can only choose between SQL Server 2005, Oracle 10g release 2 and PostgreSQL 8.3, as I want to integrate with Canonic Cadeo® For EA/QC and this is what they support.
In your experience, which of these 3 is the best please?
Thanks.
sargasso
« Reply #3 on: December 17, 2008, 11:19:45 pm »
Well, I've got to say that I've never had any problems using postgreSQL as a back end.  In fact (IIRC) after the 2-4hr intro tutorial (including the EA "how to use postgreSQL") everything "just worked".
Dorian Workman
« Reply #4 on: December 18, 2008, 08:30:05 am »
Thanks for the tip.  As it turns out, my client only supports Oracle.  So I'll try that and see how it goes.
Thomas Mercer-Hursh
  • Computing Integrity
« Reply #5 on: December 18, 2008, 10:12:40 am »
Rather simplifies the choice, eh? :)
Dorian Workman
« Reply #6 on: December 18, 2008, 07:17:40 pm »
Indeed!
