Author Topic: Code generation Path  (Read 3371 times)
cable000
« on: December 20, 2008, 09:21:40 am »
EA Version: 7.1.834
We have a fairly large base of code in C++ and java. Is their a way to specify relative to an environment variable the output for the source code.
Given a directory structure something like this ---
ROOT/src/Entity/Entity.java
ROOT/src/Capability/Capability.java
ROOT/src/ResourceManager/ResourceManager.java
I defined the 'Default Source Directory' option in Tools->Options-Java to be %ROOT%.
If the environment variable ROOT=C:\dev but another developer wants to check out the model and they define their ROOT=C:\work.
I tried to simulate this by closing EA and resetting the ROOT environment variable but when I restart EA and I go to generate the code it still wants to generate based off of the old environment variable location ( e.g. an absolute path )
Is their a way to set EA up so that the path to the source files it is generating are using a relative path?
Takeshi K
    • Sparx Systems Japan
Re: Code generation Path
« Reply #1 on: December 21, 2008, 05:27:30 am »
Maybe EA's 'Local Paths' feature helps you.
In detial, see the EA's help file, 'Local Paths' page.
Hope this helps.
t-kouno
« Reply #2 on: December 22, 2008, 08:29:22 am »
EA doesn't use the environment variables for local paths.  As was already said, look up 'Local Paths' in EA's help.
« Last Edit: December 22, 2008, 08:29:51 am by simonm »
cable000
« Reply #3 on: December 23, 2008, 06:37:18 am »
Yes I believe this is what I'm looking for. Thanks!
