Author Topic: Subversion repository--where to specify?  (Read 3535 times)
Paul Lotz
« on: January 13, 2009, 09:52:08 am »
I am trying to set up Subversion to work with EA.
I have read the "Using EA: Setting up Version Control" document, the relevant help files, and Parts 2, 4, and 5 of the Version Control demos (which were helpful).
I set up a folder in an existing Subversion repository on our network (using TortoiseSVN as in the Part 2 demo even though EA itself doesn't use TortoiseSVN) .  I'm fairly experienced with TortoiseSVN since I use it to manage my code directories.  I also set up a working copy path in the Version Control Settings dialog for a package.
What I don't understand is how to specify the repository path.  I see that information in the Version Control Settings dialog for a package in the Part 5 demo, but when I go to this dialog myself these options (also username and password) are not visible.  Must I do something else first?
Paul
Paul Lotz
Re: Subversion repository--where to specify?
« Reply #1 on: January 13, 2009, 11:36:54 am »
OK, I get it.  Once I put the folder under version control EA gets this information itself, so I don't have to worry about it.  Now I'm able to do the basics of version control OK.
I put the .eap folder in one directory (not under version control) and the .xml folders are in a directory under version control, which I gather is what I should do.
Dorian Workman
« Reply #2 on: January 13, 2009, 03:56:52 pm »
Correct!
<a href="http://www.linkedin.com/in/dorianworkman" ><img src="http://www.linkedin.com/img/webpromo/btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Dorian Workman
