Author Topic: Auto Routing To all Connectors  (Read 4373 times)
Hariharan ST
« on: January 24, 2009, 01:31:04 am »
In Data Model , i have hundreds of connectors between elements.
I have to set AutoRouting to all connectors.
Is the option "Selecting each connector --> Right Click --> Line Style --> Auto Routing " is  the only way ? or is there option to make Line Style as Auto Routing to all connectors in Data Model.
Kindly reply asap..
Hariharan
smendonc
  • I love YaBB 1 Gold!
Re: Auto Routing To all Connectors
« Reply #1 on: January 24, 2009, 12:36:58 pm »
I don't think this functionality is native to EA, but the utility at the link below claims to do what you are asking.
http://www.codeplex.com/eautils
I have not used this utility so I don't know if it works as intended.
Stan.
« Reply #2 on: January 25, 2009, 05:02:01 am »
Open the Tools | Options | Links dialog. On the upper right you will see a Default Style section. Use the Routing drop-down to select Routed.
EA will remember this setting until you change it. I believe this will also be the case if you later edit projects that were created with a different default style (i.e. I don't think this setting is stored in each project) but I am not sure. I do know that EA will not retroactively adjust connectors you have already created.
HTH, David
