Author Topic: view of testing cases with fields (precondition...  (Read 2911 times)
info007
« on: February 04, 2009, 09:53:03 pm »
Could you please tell me if       EA  offers a view (similar to that obtained by show List element) on the testing cases with the fields (precondition, postcondition, process,....)?
Thank you in advance
« Last Edit: February 04, 2009, 10:00:36 pm by info007 »
Oliver F.
    • Karl Storz homepage
Re: view of testing cases with fields (preconditio
« Reply #1 on: February 04, 2009, 11:21:31 pm »
As far as I know in EA test cases are simply stereotyped use cases so everything applying to a UC should apply to a TC also.
You can click on the required information type in the "Show Compartments" section of the element tab in a diagrams properties to make it visible. Additionally make sure to show tagged values also.
Oliver
« Last Edit: February 04, 2009, 11:21:57 pm by ofels »
info007
« Reply #2 on: February 05, 2009, 01:20:03 am »
this is for a single case of test.what i want to do  is handling several cases of test at the same time.it means: the ability to display several test cases with all their attributes (precondtion, postcondition) ,something which is very useful for a projet that have a big number of test cases.
thank you
