Author Topic: Notes view inspector for each role  (Read 2557 times)
RIL
  • -- There's always a solution --
« on: February 06, 2009, 10:42:40 pm »
Evaluating EA, looking good!
The property inspectors have improved significantly since I tried EA last time. But unfortunately I couldn't enter text in the "object inspector's" Notes view for association roles (the notes view which is displayed is only for the entire association or for a note common for all names on the association).
Q: Is it possible to arrange so that the notes view for each role is always visible like the property inspectors?
I need this very much because I enter special notation in it which I later parse/interpret with an external tool after export. This also means that I need that the Notes view for a particular role show its content directly when I click on a role name on a diagram (Now I could access the role's Notes view only by opening up the associations properties dialog).
Can I change settings somehow so that the Notes view behaves as desired?
// Rolf Lampa
