Author Topic: SysML Activity connections  (Read 3162 times)
Bharathi K
« on: February 19, 2009, 03:23:49 pm »
I am trying to structure two levels of a functional model (with activity diagrams) so that the activity parameters used in the top level modelling can be decomposed into more detailed parameters that are used at the next level, i.e. an Activity like 'Make Bread' is decomposed down to 'Mix Flour', 'Knead Dough' and 'Pour in Baking Tray' so the 'Cake Ingredients' parameter to the 'Make Bread' activity decomposes down to 'Flour', 'Sugar', etc.
Can the Activity Parameter that is instantiated to a particular Class be manipulated so that it turns up as an Activity Parameter at the next level? Currently if you connect the high level activities to to pins on the subactivities (as suggested in the SysML standard) then you have to reuse these as pins at the next level activity diagram. Can they be turned into Activity Parameters at the next level of decomposition?
If the class instantiated with the Activity Parameter is decomposed, can the child classes be used to instantiate the Activity Parameters/Pins at the next level of functional modelling?
Also object flows and activity flows on a SysML activity diagram are shown with solid lines - why doesnt EA draw the control flows in dotted lines?
