Author Topic: Activity edge connector  in activity diagram  (Read 4314 times)
akira_
« on: February 19, 2009, 03:03:40 am »
Hi
I'm looking for information how can I find and use element activity edge connector in activity diagram in EA.
Hope someone can help me,
Aga
Re: Activity edge connector  in activity diagram
« Reply #1 on: February 19, 2009, 01:17:56 pm »
If either end is an object node, use an object flow; otherwise, use a control flow.
akira_
« Reply #2 on: February 19, 2009, 07:04:43 pm »
Thank you for reply, but probably my question wasn't  precise enough.
The term i used "Activity edge connector" means notation using a connector, which is a small circle with the name of the edge in it.
I hope you can answer one more time.
« Reply #3 on: February 20, 2009, 09:11:05 am »
OK, try this: Ctrl+Click your connector twice to add two line points (bends). You now have a connector with three segments. Right-click the middle segment and select "Suppress Line Segment". This should give you what you were looking for.
« Last Edit: February 20, 2009, 09:12:10 am by KP »
akira_
« Reply #4 on: February 20, 2009, 09:58:23 pm »
Thank you for information and patience.
Best regards
Aga
