Author Topic: Is there anyway to share Styles?  (Read 3876 times)
seanassurant
« on: February 25, 2009, 02:59:21 am »
The styles bar is a pretty useful feature for standardizing color and look and feel across a shared model. When I create styles, other who are using the shared model don't seem to have access to them. Are these styles stored in the registry? Or a config file? Is there an easy way share these styles across a team.
Re: Is there anyway to share Styles?
« Reply #1 on: February 25, 2009, 04:02:21 am »
They might be stored as reference data (see the EA Help index). If so, they need to be exported from your model and imported by other users. Note that reference data is not covered by EA source control.
bioform
  • Forty-Two?
« Reply #2 on: February 28, 2009, 05:22:05 am »
Would there be away to ensure a set of reference data be propgated?
If only the short-cut feature could be used, then you could distribute that?
Time is what keeps everything from happening at once, Space is what keeps it all from happening to you. <unknown>
seanassurant
« Reply #3 on: February 28, 2009, 05:52:56 am »
We are using the shared repository version (SQL Server). I'm the only one who sees my styles.
bioform
  • Forty-Two?
« Reply #4 on: February 28, 2009, 06:29:14 am »
I understand... One way would be to define a separate EA project to hold the reference data that you want to be shared... export this...
then create an add-in to automate the process of importing this data when the project is loaded into EA.
Would seem to be pretty straight forward... Might be worth looking into...
