Author Topic: Copying in Sparx  (Read 3334 times)
Peter Bull
Copying in Sparx
« on: March 11, 2009, 11:10:10 pm »
Hi
I have created a deployment node containing components (one component contains other components).
How can I copy the node (including components and their dependencies) to another package in the same model?  I need an almost identically configured DR node and also the same node in other environments and do not wish to re-create it manually.
Regards
Pete
Re: Copying in Sparx
« Reply #1 on: March 11, 2009, 11:47:02 pm »
The only way I know is to export to xmi and then import with the option "Strip GUID"
Dermot
« Reply #2 on: March 12, 2009, 11:45:04 am »
Apart from using XMI, elements selected in a diagram can Copied & Pasted as "New", but this will not include the conectors.
If it is used frequently you migh like to look at using a UML Pattern - see:
http://www.sparxsystems.com/uml_tool_guide/what_is_uml_modeling/umlpatterns.html
Peter Bull
« Reply #3 on: March 14, 2009, 12:43:46 am »
Thanks chaps.
I copied by export/import of the entire package (I wanted to retain relationships) and will probably use patterns for another project I am working on.
Pete
