Author Topic: Reverse engineer VB6 code  (Read 3227 times)
Rajesh Hanchate
« on: March 17, 2009, 11:29:28 pm »
I am working on reverse engineer VB6Code, Can I debug VB 6 code and generate Sequence diagram? Is that possible using EA v6.5?
Please let me know if anyone worked on it?
Rajesh
« Last Edit: March 17, 2009, 11:31:22 pm by rhanchate »
Re: Reverse engineer VB6 code
« Reply #1 on: March 18, 2009, 01:15:57 am »
[edit]See the following post; with some limitations it is possible.[/edit]
I don't think so. I believe EA can only debug .Net and Java code.
At least that might have to been the case in EA 6.5. Check the EA help to see if things have changed since. You might also want to check the release notes for EA 7.5 as it comes out.
« Last Edit: March 18, 2009, 09:25:31 pm by Midnight »
« Reply #2 on: March 18, 2009, 09:21:56 am »
You can also debug any Microsoft native code, including C++/C/VB6, as long as you have a .pdb file (and you're debugging on the same machine that created the .pdb)
