Author Topic: Comments away after source file import - c++  (Read 2158 times)
Elmi
« on: March 24, 2009, 05:14:06 am »
Hi guys,
When generating source code I'm using own genration templates to get Doxygen compliant comments.
If I now want to reimport the source files, all comments are wrong.
Example of a function header after export:
\brief          Little Description
\param [in] newVal : Description of newVal
CMyClass::MyFunction(const int newVal)
After import and export again:
\brief          --------------------------------------------------------------
The function description is wrong and the paramter description is empty.
What can I do to solve this problem.
Best regards
Elmar
« Last Edit: March 24, 2009, 05:16:08 am by Elmi »
Re: Comments away after source file import - c++
« Reply #1 on: March 24, 2009, 10:25:42 am »
Well, here's what is happening.
EA takes the previous comment before a code element to use as the notes for the corresponding model element.  This is highlighted below.
So your note will be set to
So then you generate back out again, and it puts that value into your templates and gets the output you described.  I don't know what happened to your parameter notes.
As I have mentioned a few times on the forum.  Changing the templates to generate Doxygen is easy.  But EA won't reverse engineer or synchronize with this properly.
