Author Topic: Adding model search result to diagram  (Read 3314 times)
armin
  • mission possible
« on: March 25, 2009, 02:31:53 am »
Hi all,
I have the following EA-modelling use case:
create a dieagram which contains all component elements in my model. This diagram should be maintainable as easy as possible.
To excecute this use case I searched all component elements in my model. My idea was to add the search result into my diagram. Is there a way to do this?
Does anyone has an idea how to solve the use case in another way?
Thanx & Regards Armin
« Last Edit: March 25, 2009, 02:32:33 am by armin »
Re: Adding model search result to diagram
« Reply #1 on: March 25, 2009, 09:07:50 am »
There's an option in the search window to show the results in the output window.  From this view you can drag the results to a diagram.  Alternatively, create a model view from the search.  You can drag onto the diagram from there, or just use that view directly.
armin
  • mission possible
« Reply #2 on: March 25, 2009, 06:05:29 pm »
Cool hint... Thanx!  :)
