Author Topic: Adding a Requirement Type to an RTF document  (Read 2657 times)
Glyn
« on: March 26, 2009, 09:33:39 pm »
Hello all - another new member here with hopefully an easy to solve problem.
We are creating a template to document our Requirements using a very simple RTF template which is then inserted into our standard corporate Word documents.
So far this is OK, but I cannot see how we can add one particular property of the requirement element to the RTF template.
Our requirements are grouped in a series of Packages and associated elements under "Requirements Model".  I can include the name and notes for both the packages and elements into the template but cannot see how to include "Type" from the requirement element - by Type I mean "functional" "performance" "report" etc that appear in the drop-down list under "Type" when you create a new Requirement.
If I insert the field {Element.Type} into the template, the end result is always "Requirement" - which is reasonable as this is the Type of element I'm working with.
So - how do I get the document to show "functional" "display" "reporting" etc against each requirement?  I've tried just about all of the fields available when I right-click the template but cannot find the right one.
I've included (below) the template we are using.
Many thanks in advance.
package >
{Pkg.Name}
{Pkg.Notes}
element >
        {Element.Name}      {Element.Notes}
child elements >
< child elements
< element
child packages >
< child packages
< package
BTW - we are using Ent Arch v7.1.834
Dorian Workman
Re: Adding a Requirement Type to an RTF document
« Reply #1 on: March 27, 2009, 05:51:07 am »
That field is actually the Element Stereotype field (confusing I know).
<a href="http://www.linkedin.com/in/dorianworkman" ><img src="http://www.linkedin.com/img/webpromo/btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Dorian Workman
