Author Topic: More reading material about Code Engineering  (Read 2145 times)
Kim Lillås
« on: April 02, 2009, 01:53:40 am »
I´m looking for more material about "Code Engineering" in EA (Im a beginner in the subject). The functions, like "synchronize package with code", does not work exactly like I expect them to.
I would like to better understand the functionality, as it sometimes seem almost inconsistent.
As an example, lets consider synchronizing from model to source only.
-I add an attribute "int test1" into a class
-I synchronize
-The attribute has been added to the source
-I remove the "int test1" from the class in the model
-I synchronize
-int test1 is not removed from source
This seems a bit strange to me, as at a first glance I would assume that the source should reflect the changes I did in the model.
Cheers,
Kim Lillås
Re: More reading material about Code Engineering
« Reply #1 on: April 02, 2009, 03:45:26 pm »
Look at the options dialog.  On the Attribute/Operations page is the option to prompt when something isn't found in code.
