Author Topic: Image Name  (Read 2393 times)
dsargrad
Image Name
« on: April 09, 2009, 01:16:08 am »
I'm running the following command:
Project/Documentation/Diagrams Only Report
I want to be able to generate diagrams and have their names be recognizable on disk. For example a sequence diagram with the name "Startup" might be named "sd Startup.gif" on disk. Currently the name of the images on disk mean nothing to me.
I need this so that I can then integrate these images easily into my design documentation (separate process). I have tried the alternative which is to create the diagrams in an RTF file. I then copy/paste these images into my design documentation. However I have run into problems with this approach.
Is there an easy way to tell EA to "use developer assigned file name" (where the assignment is no different than the diagram name)?
