Author Topic: Version 6.5 - Released (Build 798)  (Read 17609 times)
sparks
« on: September 27, 2006, 12:57:39 am »
Added ability for UI Control elements to own other UI Control elements
Added ability for Requirement elements to own Feature elements
Fixed UML Profile import to tolerate blank version number
Improved importing of XML Schemas and Schemas spanning multiple XSD files
Stopped generation of implementation file for C++ typedef classes
Corrected some parsing errors for code importing
Added support of operation behavior to transformations
Added commands for code engineering and transformation functions automation interface.
Corrected issue with tree style connectors where both horizontal and vertical styles could be activated at the same time.
Corrected issue with displaying labels with wrapped Japanese characters.
Improved RoundRect shapescript command by preventing the rounded corners from overlapping.
Improved TFS version control configuration to query TFS for Server and Workspace names associated with the specified Working Copy folder.
Corrected TFS "add" operation to add the package file to the repository, rather than create only a pending changeset.
Improved version control initialisation when loading model, to verify existence of all working copy folders specified in VC configurations.
Improved filename generation/checking when adding files to version control - remove illegal chars from package names when creating filename.
Corrected the link for the Help button on the version control "Get Shared Files" dialog.
Improved reporting of version control status when package is "Checked Out Offline" in  a shared model.
Improved version control status reporting through Automation Interface.
Improved handling of packages associated with Version Control Configurations that are incomplete - no longer handled as though VC Offline.
Added ability to create connections to elements off screen by scrolling the view.
Added ability to create a selection rectangle to elements off screen by scrolling the view.
Corrected issue of triggers not loading correctly with old data.
Added ability for ExpansionRegion elements to own Object, ExceptionHandler and ExpansionRegion elements.
Corrected issue saving Requirements when locale is set to Bulgarian.
Added Swimlane support to automation interface.
Prohibited the creation of non-creatable automation classes.
Resolved issue where creating automation elements using invalid types returned corrupted elements.
Modified code templates for C++ to not generate constructors for unions
Modified the DDL transformation to copy attribute notes to the column notes
Transitions with multiple Triggers now display correctly.
Fixed OCL validation error on collection iterations.
