Author Topic: Can I put serveral models in one SQL database?  (Read 3024 times)
Dan Moran
« on: April 15, 2009, 01:17:57 am »
This is probably going to sound like a silly question to long time EA users, but I haven't been able to find the answer in the documentation or here on the forum. The question is...
Can I put more than one model in a single SQL Server 2005 database or do I have to create one SQL Server database for each model? If it's possible to put more than one model in a single database, how is it done?
Any help on this would be appreciated. Thanks.
 - Dan
Dermot
Re: Can I put serveral models in one SQL database?
« Reply #1 on: April 15, 2009, 11:51:16 am »
Each EA repository does require a seperate Database on the SQL server (however you can have multiple Projects/models within one repository).
Aaron B
« Reply #2 on: April 15, 2009, 12:01:41 pm »
To add to what Dermot said, the Full Model Data Transfer feature only allows for transfer of one model file into your DBMS repository.  Attempting to transfer a second model file will overwrite the first.  To add a second model into your DBMS repository, you will need to perform an XMI Export from your original model and Import the resulting file into your DBMS repository.
« Reply #3 on: April 15, 2009, 03:13:08 pm »
To actually add another model you have to right-click on the top level element in the tree and select "New Model (root node)..."
