Author Topic: OCL Constraints  (Read 3876 times)
krizz
OCL Constraints
« on: May 08, 2009, 12:02:16 am »
I am using an UML Profile, which I defined in Enterprise Architect.
Is there a way in EA to add OCL constraints to that profile?
Re: OCL Constraints
« Reply #1 on: May 08, 2009, 09:53:06 pm »
Yes,
In the EA help index - at least for EA 7.5 build 844; it might be in a different place for earlier versions, but I think it will still work - look up Profile | Constraints. You create these on a per-stereotype basis.
In essence you are defining class constraints as you normally would, but the 'class' involved is a stereotype you define in your profile.
As with anywhere you use OCL with EA, your results may not be quite what you expect. Play around a bit if things don't appear to work perfectly the first few times. Sometimes it is more a question of how you do something (in EA) than what you do. Things often become easier once you start doing things the way EA expects.
Kevin G. Watson
  • I love EVERYTHING including Microsoft
Re: OCL Constraints
« Reply #2 on: May 09, 2009, 10:06:34 pm »
Hello
is that a unique experience to accompany the unique interface:)
Kevin
Re: OCL Constraints
« Reply #3 on: May 11, 2009, 12:55:30 am »
More likely coincidence than accompaniment...
