Author Topic: Import SQL Schema  (Read 4062 times)
Edward Stow
Import SQL Schema
« on: May 22, 2009, 12:46:32 pm »
I would like to import a schema defined using SQL DDL.
Is this possible?
Using EA Professional
Edward
hd
Re: Import SQL Schema
« Reply #1 on: May 22, 2009, 02:35:40 pm »
If you mean importing from a DDL script file - no that is not possible.
However, you can import database schemas through ODBC - refer...
http://www.sparxsystems.com/uml_tool_guide/data_modeling/importdatabaseschemafromod.html
Edward Stow
« Reply #2 on: May 22, 2009, 02:59:11 pm »
Yes thats what I meant ... pity .. I am working from some legacy application source code that needs re-engineering, but however it is not an installed system.
salayande
  • I love YaBB 1 Gold!
« Reply #3 on: May 23, 2009, 09:26:53 pm »
Surely if EA can read and parse XML Schema files and create a physical design model, I cannot see why it should not be able to read DDL scripts and create relational design models.
Sparxsystems should consider this query as a product improvement opportunity.
Segun
« Last Edit: May 23, 2009, 09:28:03 pm by salayande »
Edward Stow
« Reply #4 on: May 24, 2009, 08:02:07 pm »
I can see it would not be that easy to import from a variety of SQL Dialects (compare MySQL with Oracle for example) but it would be a nice feature.
Edward
