Author Topic: SQL editor with SUBSELECT  (Read 3555 times)
viarellano
« on: May 18, 2009, 11:41:43 pm »
is there any possibility to do a query definition with a subselect?.
When i tried it, EA gives me next error msg:
SELECT * FROM (SELECT *  FROM t_object);
DAO.QueryDef [3131]
Syntax Error in from Clause.
Thanks!
Vi
Wyatt
Re: SQL editor with SUBSELECT
« Reply #1 on: May 21, 2009, 03:26:41 pm »
That syntax is not valid in the standard Jet engine.  If you choose the option to use Jet 4.0 (tools | options -- restart required), it will work as expected.
viarellano
« Reply #2 on: May 25, 2009, 11:38:00 pm »
thanks
it is posible to set this value to the SqlServer deployed version of EA ?
regards
