Author Topic: Export package to XML - invalid file name  (Read 3584 times)
« on: June 09, 2009, 11:05:55 am »
I'm trying to export a package to XML.
I browse to the folder using the [...] button.
The resulting filename is
\\hocfs02\is group\X Systems Architecture\Architecture Team\Team member folders\Simon\TKDM_xmi.xml
When I click on export I get is "You must specify a valid path for the export file".
Yet the path is valid.
Any ideas?
Frank Horn
Re: Export package to XML - invalid file name
« Reply #1 on: June 09, 2009, 04:05:51 pm »
Seems like this message can mean just about anything. I remember getting it when I tried to export a controlled package which was under version control, and inadvertently chose the local working copy xmi file as destination. Of course in your case the reason for the destination being "invalid" could be something else.
« Reply #2 on: June 10, 2009, 07:38:10 am »
Well the obvious suggestion is that EA does not support UNC paths.
Tell me it isn't so.
« Last Edit: June 10, 2009, 07:38:36 am by skiwi »
