Author Topic: RefactorEA  (Read 31801 times)
Martin Terreni
  • Sorry, I can't write
Re: RefactorEA
« Reply #30 on: June 09, 2009, 06:13:27 am »
H
Martin:
This is an open source project...and so a partnership like yours would be immensely appreciated. Perhaps we can move to Source Forge as a source repository or something...what do you think?
I'm in a very large company, so unfortunately, it may take a couple of months till we decide to get into it (which I believe will happen) then I'll try to release the more generic parts.
I hope we get to it.
Recursion definition:
cube1us
Re: RefactorEA
« Reply #31 on: June 11, 2009, 07:36:27 am »
FYI, I thru C# 2008 Express on my machine, and after discarding the FGS stuff owing to its Office dependencies to simplify things, I was able to confirm that both suggestions I had fixed the bugs I found.
Relevant code snippits:
 if (_target != null)
                if (_target.ElementID == A.ElementID)
                    _source = B;
                else
                    _source = A;
This fixes the problem where it said it could not merge an element onto itself.
       private void MergeConnectors()
            int changed = 0;
            for (short i = 0; i < _source.Connectors.Count; i++)
                try
                    EA.Connector c = (EA.Connector)_source.Connectors.GetAt(i);
                    //  If the connector already points to the target, leave it alone,
                    //  as there might be a connector between source and target.
                    if (c.ClientID == _target.ElementID ||
                        c.SupplierID == _target.ElementID)
                        continue;
                        EA.Connector newConnector = (EA.Connector)_target.Connectors.AddNew(c.Name, c.Type);
                    ++changed;
                    if (c.ClientID == _source.ElementID)
                        newConnector.ClientID = _target.ElementID;
                        newConnector.SupplierID = c.SupplierID;
                        c.ClientID = _target.ElementID;
                    else if (c.SupplierID == _source.ElementID)
                        newConnector.ClientID = c.ClientID;
                        newConnector.SupplierID = _target.ElementID;
                        c.SupplierID = _target.ElementID;
                    _source.Connectors.DeleteAt(i, true); i--;
                    _source.Update();
                    if (ShouldAddConnector(newConnector))
                        newConnector.Update();
                    c.Update();
                catch
                    //log and continue
            MessageBox.Show("Changed Elements: " + changed);
The above makes merges successfully using the simpler method we discussed earlier, and also throws up a dialog box containing the numbrer of changes (should say changed connectors).
In brief testing, I was unable to break the merge with these chnages in place -- but I am only using the simplest of test cases.
