Author Topic: How to Find Which Diagrams Are Open  (Read 3011 times)
Brian Wilkinson
« on: August 28, 2008, 09:32:33 pm »
Is there a way of find which diagrams are open in the broswer window.
I don't seem to be able to find a property on a diagram that says if it open in the browswer or a collection of which diagrams are currently open.
Can any one help out?
                                  Brian
Re: How to Find Which Diagrams Are Open
« Reply #1 on: August 28, 2008, 10:12:12 pm »
Good question Brian,
Without proof - I don't generally program against running instances of EA so I have not had to try this (yet) - I suspect you need to check the list of open 'tabs' for your diagram.
There might be some catches to this. In no particular order:
  • This might not be the correct approach at all...
  • There does not seem to be any documented standard for tab names; you'd have to come up with something yourself, including some means of handling duplicate (unqualified) diagram names.
  • There are tabs in various places in EA; the documentation does not say how these are distinguished (or whether they are at all).
The things I am talking about are all Repository methods. Take a look at ActivateDiagram [just for a reference to the "tab" idea], ActivateTab, ClearOutput, CreateOutputTab, EnsureOutputVisible, IsTabOpen, OpenDiagram [for another reference to the "tab" attribute], RemoveOutputTab, SaveDiagram [which also references the "tab" of a diagram window], and WriteOutput [once again with a reference to "tab"].
Just to make the earlier point really clear, the above is a guess, and should be treated as such. Test everything...
