Author Topic: Trigger type in state machine diagram  (Read 3201 times)
objectinfo
« on: May 29, 2009, 03:22:59 pm »
Hello All,
In a state machine diagram, when you specfify a transiation from one sate to another, in the 'StateFlow Properties', for the Trigger, you can specify the type as one of the following: 'Call', 'Change', 'Signal', 'Typ'.
Please can somebody explain what is the significance of these types?
jjyoung
Re: Trigger type in state machine diagram
« Reply #1 on: June 02, 2009, 07:43:12 am »
'Call' - specifies that the event is a CallEvent.  In other words, it sends a message to the associated object by invoking an operation.
'Change' - specifies that the event is a ChangeEvent.  This indicates that the transition is the result of a change in value of an attribute.
'Signal' - specifies that the event is a SignalEvent.  This corresponds to the receipt of an asynchronous message.
'Typ' - I think you actually meant 'Time' here.  This corresponds to a TimeEvent.  In other words, and event that specifies a moment in time.
objectinfo
« Reply #2 on: June 03, 2009, 09:14:53 pm »
Thanks! That was really helpful.
Sterling
« Reply #3 on: June 20, 2009, 03:59:06 am »
Unfortunately, actually adhering an operation of the owning classifier doesn't seem possible in EA? ... as far as my investigations go.
Strg
