Author Topic: Multiple stereotypes for Requirement elements  (Read 4492 times)
DanG83616
« on: June 20, 2009, 06:58:20 am »
The Stereotype Selector help page shows how to select more than one stereotype for an element. I cannot figure out how to get to the Stereotypes dialog from a Requirement element properties dialog. Anyone know how?
Also, the Requirement dialog presents Type rather than stereotype. I can type in the stereotype but I'd like to get the stereotypes in the pulldown rather than the type list. Any tips?
Dan
OneCent
Re: Multiple stereotypes for Requirement elements
« Reply #1 on: June 23, 2009, 12:40:20 am »
Try:
1) select View Properties
2) Open the Drop Down List on Stereotype
3) select "browse other stereotypes"
Maybe that brings you to the point you want.
Cheers, OneCent
DanG83616
« Reply #2 on: June 23, 2009, 03:08:39 am »
Ah, thank you, OneCent. The trick is to use the Properties view panel rather than the context menu Properties... dialog. It looks like each time I select a stereotype it gets added to the list and selecting the blank line erases the currently displayed one.
Is there a way to view the list of stereotypes I've added to the element?
There is an interesting interaction between stereotype and type. Depending on which stereotypes I add, the type sometimes changes.
