Author Topic: EA Auditing  (Read 4885 times)
Shailen
EA Auditing
« on: June 19, 2009, 11:34:17 am »
Quick EA question regardining auditing.  I have a model that comprimises of many attachments to documents.  I've created a document index detailing all the attached documents throughout my model. The model is quite big, so the index lets a user access the document if they don't know which business process it would be associated to.  I want to run and audit that tells me exactly where all the documents are located within my EA model.  Also I would like it to tell me if there are any documents that is listed in my index but not associated in my model.  How can I do this?
Thank You.
Dermot
Re: EA Auditing
« Reply #1 on: June 22, 2009, 03:04:16 pm »
Are you storing these as Linked Documents/Document Artifacts or linked via Element.Files?
Shailen
Re: EA Auditing
« Reply #2 on: June 23, 2009, 06:55:19 am »
We are storing them as linked documents/document artifacts
Dermot
Re: EA Auditing
« Reply #3 on: June 23, 2009, 03:02:00 pm »
Try doing a Ctr-F Custom SQL search on the table: t_document - using something like:
SELECT ea_guid as CLASSGUID, Object_Type as CLASSTYPE, Name
FROM t_object, t_document
where t_object.ea_guid =  t_document.ElementId and t_document.Doctype ='ModelDocument'
The context menu of the result set does allow for reporting the results.
