Author Topic: Relationship matrix  (Read 3701 times)
Ian McSmith
Relationship matrix
« on: June 18, 2009, 01:57:53 am »
Is it possible to include a relationship matrix with a template for an RTF document?
Matias Burni
Re: Relationship matrix
« Reply #1 on: June 20, 2009, 03:49:28 am »
I need the same feature. There is any way to export the "Relationship Matrix"???
I read all the tutorials but do not mention anything
Dermot
« Reply #2 on: June 22, 2009, 03:13:20 pm »
The relationship matrix is not currently supported in the RTF generation, however an option you can look at using is:
- Export the relationship matrix to a CSV file (Use the Options Menu of the relationship matrix).
- Open the CSV file in Excel
- Auto-format the cells with the 'x' to shrink them
- Format the first row text to 90 degrees
- Ensure column A is broad enough for the text.
- copy the cells
- open a Linked Document or Document Artifact in EA
- paste the matrix
- select the first row and using: Table | Rotate Text - rotate the text 90 degrees.
In the RTF report template include Element::Model Document.
Graham_Moir
« Reply #3 on: June 24, 2009, 01:07:00 am »
Longwinded, but a useful workaround
Matias Burni
« Reply #4 on: June 24, 2009, 01:24:30 am »
The solution is is not the best, but is a solution at the end. I will paste a print screen. It is not dynamically but it work better to me.
