Author Topic: HTML reporting - linked files  (Read 2887 times)
Graham_Moir
« on: June 24, 2009, 03:15:01 am »
It looks as though any linked files added through the "Files" tab on an element are not copied into the folder structure created when generating the html (although this is done for the logo file if you specify one).   The initial html works with a reference outside of the folder sructure,  but this approach means that these links are lost if you lift the output folder structure and deliver it somewhere else.
Interestingly the folder structure created does have a "files" folder within it, but it is empty in my case.
So,
1) is this a bug or a feature ?
2) anyone have a workaround ?
thanks
« Last Edit: June 24, 2009, 03:16:19 am by Graham_Moir »
