Author Topic: Model transfer  (Read 5294 times)
Mr. Sanders
  • Dilbert for president
Model transfer
« on: June 26, 2009, 05:31:17 pm »
I try to transfer an EAP file to an MS SQL Server, but I always get the message:
Could not open target database.
I already tried a couple of things, e.g. assigning the user do the admin roles, give him all right explicitly, ...
Nothing works.
We use Windows Authentification.
Is there a hint to solve this?
Regards
Michael
Mr. Sanders
Re: Model transfer
« Reply #1 on: June 26, 2009, 10:17:22 pm »
after droping and recreateing the DB everything worked fine.
I don't care anymore.
Thank you
David Myers
Re: Model transfer
« Reply #2 on: June 27, 2009, 01:33:55 am »
I got the same problem. When I test the connection it connects ok, but then when I click on the transfer button on the Project Transfer page it works comes up with the error "Could not open target database".
I created the necessary tables using the script from the website and did the same on a local database. I could transfer to my local database but not a remote database.
Clearly there is something different in terms of the setup of the non-local database, but because there is nothing that specifies the setup of the sql server database in order to use EA I have nothing to go back to the DBA's with.
Anyone have an idea how to resolve this issue, or even where to start?
Mr. Sanders
Re: Model transfer
« Reply #3 on: June 27, 2009, 01:41:18 am »
Hello David,
I had these problems with the sql native client.
When I switched to ole db provider for sql server I was able to access the db.
Did you configure the remote sql server, that it allows remore connections?
Regards
Michael
David Myers
Re: Model transfer
« Reply #4 on: June 27, 2009, 01:55:46 am »
I found the issue when trying to connect to the remote database after transfering my local data to it. I got the following error:
[DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied.
I then found that this is a MS issue and there is a work around by specifying the port explicitly in the connection string as described in the following KB article:
http://support.microsoft.com/kb/888228
Hope this helps someone else!
Mr. Sanders
Re: Model transfer
« Reply #5 on: June 29, 2009, 05:36:57 pm »
the standard Ports are
TCP: 1433
UDP: 1434
Michael
