Author Topic: Reduce diagram size for copying to clipboard  (Read 3909 times)
Franz P.
« on: July 02, 2009, 07:46:52 pm »
Hi, newbie question: How can I reduce the diagram size when I copy the diagram to clipboard. At the moment I have a lot of space between my elements and the right border of the diagram frame. I assume the reason is a changed diagram layout. But I did not find any possibility to reduce the diagram size.
robbierzzz
Re: Reduce diagram size for copying to clipboard
« Reply #1 on: July 02, 2009, 08:13:12 pm »
You could try to resize it with; Diagram -> Properties -> Diagram -> Page Setup and then scale it in the Advanced section to whatever size you want :).
Dance with the stars
Franz P.
« Reply #2 on: July 02, 2009, 08:40:52 pm »
Thanks for the reply, but this does not help. There is still too much space between my elements and the diagram frame.
What I am missing is to adjust the diagram size to fit exactly around my elements.
paddler
« Reply #3 on: July 03, 2009, 04:16:14 am »
One thing you CAN do is export the diagram as a GIF or BMP ( I think you right - click on the diagram and there is a "Save Drawing" icon)
 Then, open the diagram using MS paint and crop the borders to your liking
 Hope this helps
 PT
"perfect is the enemy of good enough" - Voltaire
Franz P.
« Reply #4 on: July 03, 2009, 05:38:14 am »
This is what I am doing now, but it is not satisfying to me. I would like to avoid manual editing of the image. Furthermore for a better quality I would like to have the diagram in metafile format.
« Reply #5 on: July 03, 2009, 10:49:57 am »
It should just be working.  Unless you have swimlanes etc, in which case they will contribute to the size of the resulting diagram.
Another possibility is a hidden element of some sort further out.  Try the pan and zoom window for an overview of where elements exist.
Finally, if you select a set of elements and copy, it will include only those elements (with a bounding rect only around them) to the clipboard.
