Author Topic: reverese engineer getter & setter property rules  (Read 3102 times)
Derek V
« on: August 15, 2009, 03:30:50 am »
How can I change  the settings in EA so that when I reverse engineer Java code to UML, the property features are automatically set for attributes whose getter & setter methods are named by way of capitalizing the first letter of the attribute.
This:
myAttribute
getMyAttribute()
setMyAttribute()
Not this (which is used by default):
getmyAttribute()
setmyAttribute()
Re: reverese engineer getter & setter property rul
« Reply #1 on: August 16, 2009, 03:25:15 am »
When you reverse engineer - from source code to UML - EA should only create methods (including getters and setters) that it finds in your code.
Regardless, there are options for naming these on the Tools | Options | Source Code Engineering dialog towards the bottom. Note that these are not on the language-specific pages under that dialog.
Derek V
« Reply #2 on: August 20, 2009, 12:27:29 am »
Thanks so much Midnight!!!
That's exactly what I needed to know.
I was looking in the Java Source Code Engineering (not the General section).
« Last Edit: August 20, 2009, 12:28:21 am by derekvre »
