Author Topic: Supported Attributes on Stereotypes  (Read 3391 times)
Hannes Stauss
« on: December 12, 2007, 05:55:12 am »
Hi!
Just tried to define a stereotype with a supported attribute as described here
http://www.sparxsystems.com.au/EAUserGuide/index.html?supportedattributes_2.htm
What I want to achieve is to show all tagged values on a stereotype whenever one drops the stereotype on a diagramm from the toolbox. Therefore I added the supported attribute
_Tag: int = 1
to my stereotype that extends an Actor metaclass. I assumed that the tagged value will be hidden in the tags view and that all tagged values show up when the stereotype is dopped on the diagram.
However, neither all tags are shown nor is "Show Element Compartments: Tags" checked in the feature visibility dialog. Moreover, the _Tag tag is an editable tag in the tagged values view.
Thanks for any hints in advance.
Hannes
Frank Horn
Re: Supported Attributes on Stereotypes
« Reply #1 on: December 12, 2007, 07:37:24 am »
Had that problem myself some weeks ago. It's simple however: you have to define the _Tag attribute not on the stereotype, but on the metaclass. It plainly says so in EA help
The following attributes can be applied to metatype Classes in UML Profiles, and refer to the stereotypes that extend them
but I overread it first time too, because it's so weird.
Frank
Hannes Stauss
« Reply #2 on: December 12, 2007, 09:45:11 am »
Thanks Frank,
that solved the issue.
Regards
Hannes
Banvari Lakhotia
« Reply #3 on: August 24, 2009, 07:02:54 pm »
I came across your discussion about Tag's visibility. I followed the same process, all tagged values on a stereotype visible when one drops the stereotype on a diagram from the toolbox. But the same could not be achived with automation script.
here is my process:
1. Add element.
2. assign stereotype from profile
3. Update element
4. Project.CustomCommand() - to get all tags available
5. Update all tags values
6. Add diagram object and assign element reference.
7. Update diagram object.
When I go to diagram, I could not see available tags. I have to go to diagram properties -> element -> check the box for Tags visibilty and to see all tags.
Is any step missing in automation? Appreciate your feedback.
Banvari
