Author Topic: data types do not appear data model tables  (Read 3013 times)
MarkA
« on: August 21, 2009, 05:23:52 am »
I'm attempting to generate a DB schema for an Oracle database.  In the class diagram, I'm unable to add a column other than the primary key.  The data types do not appear to load in the drop-down menu.
Would someone please tell me what I'm missing?  :-?
The version is an EA trial, version 7.5.845 (build 845), Unicode.
[smiley=dankk2.gif]
hd
Re: data types do not appear data model tables
« Reply #1 on: August 21, 2009, 07:59:03 am »
You probably haven't set the target database from the Database: drop down.
The default database can also be set from Tools | Options | Code Editors | Default Database.
MarkA
« Reply #2 on: August 25, 2009, 12:10:34 am »
Thank you, hd!  When I couldn't find that setting, I did an import of an existing Oracle database, and it populated the setting to "Oracle".
