Author Topic: Using Automation to Import DB Schema from ODBC  (Read 4567 times)
Derek Poulin
« on: September 17, 2008, 07:59:51 am »
I'm trying to use automation to import our database schemas into EA, but I don't see how to do it. Does the automation API support this? Can someone please point me in the right direction?
Derek
jkorman
Re: Using Automation to Import DB Schema from ODBC
« Reply #1 on: September 17, 2008, 08:26:35 am »
Create a class diagram
Right click for a context menu - select [Import DB schema from ODBC]
brings up a dialog where you need to select "stuff"
Works pretty well!
Jim
Derek Poulin
« Reply #2 on: September 17, 2008, 08:37:34 am »
Clarification: I would like to do this programmatically, not manually. That is, I want to create a Windows console application that calls into the EA automation API:
        static void Main(string[] args)
            // Get app settings:
            string project = ConfigurationManager.AppSettings["Project"];
            // Open EA:
            EA.Repository repository = new EA.RepositoryClass();
            // Open the project specified in the app's configuration file:
            repository.OpenFile(project);
            // Do the Import DB Schema from ODBC:
Any ideas how to do this?
Derek
« Reply #3 on: September 17, 2008, 09:08:59 am »
I believe this is not possible, at least not yet.
This remains a significant omission in the EA feature set. I have no idea if Sparx is working on it; even if they are it might be a "future version" thing.
Perhaps you could request this feature. The more of us who do, the greater chance Sparx will recognize it as a priority.
To do so, follow the Feature Request link below the Support link near the bottom of any forum page.
