Author Topic: XMI export, which version to use  (Read 2901 times)
« on: September 24, 2009, 07:00:55 am »
When doing a XMI export two XMI types are offered 1.1 and 2.1
The default appears to be 1.1.
Which type should I choose?
And why?
TIA
PS I note from the help that the compare diff utility only works on 1.1
Re: XMI export, which version to use
« Reply #1 on: September 24, 2009, 04:08:30 pm »
I think it only depends on what you want to do with the xmi export.
You've answered part of the question yourself, if you want to use it to compare model/packages then you want to use v. 1.1.
