Author Topic: Virtual and Resource Documents  (Read 2656 times)
ebeb
« on: October 02, 2009, 05:54:52 pm »
I just created some Virtual Documents by selecting the template to use and packages to inlcude. But no matter what V-doc I use to create, EA uses the same RTF file name. Then, there are resource documents, which will remember the RTF configuration including the file name.
So is there a way to store the file name within the v-docs? Or can I use resource docs in combination with v-docs?
Why are there two almost similar ways to create preconfigured documents? Which is intended for what use?
thanks,
jan
Luis J. Lobo
  • IT Consultant
Re: Virtual and Resource Documents
« Reply #1 on: October 02, 2009, 09:07:16 pm »
Yes, it's possible to select the virtual document, hit F8, set the "Name" of the RTF document, select the RTF template to use, and press "Resource Docuement" to remember this configuration.
