Author Topic: How best to gather data requirements  (Read 3269 times)
lucky
« on: October 10, 2009, 12:44:36 am »
I'm looking for a way in EA to gather some system requirements and need to capture requirements for input and output fields from a system.  Is there a way of capturing requirements in EA for an interface that includes attribute name, type, size, format, mandatory?
The data modeler seems too tied to a database, whereas my data could be expressed simply as XML.  Has anyone used EA to capture data requirements & constraints?  If so, what diagram did you use?
Paul Lotz
Re: How best to gather data requirements
« Reply #1 on: October 10, 2009, 03:14:37 am »
There are a couple things your question could mean, but, yes, it is possible (ideal, really!) to model data interfaces in UML and EA using a class diagram.  Each class can have attributes and it is trivial to spell out the name, type, size, and other properties--even custom properties--for each parameter.  We do this for each subsystem we design and develop and find it to be an an indispensable and time-saving technology.
The interface element is available on class diagrams if you want to define an interface in a technical object-oriented sense, but I'm not sure that's what you want to do.
EA also has a special database-modeling tool, but it doesn't sound like you are really looking for that, either.  I recommend starting with a class diagram.
jfzouain
« Reply #2 on: October 10, 2009, 04:50:50 am »
Hi
What ever Paul told you, it is true.
But before going that way look into Raquest, add-on for EA.
Looks like you are in DW project, good tool for this.
Jose
Best regards
Jose Zouain
