Author Topic: Version 3.10 - Build 479 released  (Read 36256 times)
sparks
« on: April 03, 2002, 05:02:17 am »
Enteprise Architect Version 3.10 - Build 479
Changes and fixes for Build 479
- Sequence diagram messages may now be offset vertically to open or close the gap between consecutive messages - drag into position with the mouse
- Connectors of any type may now have an attached note - the notelink will attach at the link centrepoint and is currently fixed to that point. Use link context menu to attach a note
- Connectors may have an attached constraint - use the context menu of a connector to create one - then check all relations that participate in constraint set
- Added a Local Option to the Sequence page to set the default sequence diagram page layout as Landscape
- Fixed a bug in the relationship matrix that prevented new 'X' characters showing when link created
- Modified relationship matrix such that if the specified direction is 'Target->Source' then new links will follow this direction as well
- Changed image name when generating RTF documents to derivative of diagram GUID - provides image independence to document version
- Removed pichgoal and picwgoal settings from generated RTF for embedded image - was causing problems in Word XP documents
- Automatically generated implementations of interfaces in C++ had wrong scope(namespace) - fixed
- Run state dialog now fetches all attributes in the classifiers ancestry to choose from
- Removed ' and ' characters from run state instance variables when displaying
- Diagram images could have erroneous white space when generating RTF documents - corrected
- Prevent creation of duplicate realisation links when dropping requirements on other objects
- VB.Net parser import of function parameters and types with array modifiers corrected
- Added option to Object page of Local Settings dialog to show/hide arrowheads on Uses link
- Added code to permit bi-directional dependency and realisation links
- When view window is scrolled away from (0,0), moving elements beyond left or top border is now handled more intuitively
- Problem duplicating diagrams with JET 4 and replication enabled (s_ColLineage field causes diagram copy to fail) - corrected
- Fixed problem with Delphi generation of Properties - public property being  skipped on first file generation
- Sequence messages and collaboration messages now pick up the default parameter names from operations when  selected in message dialog
- Added Node, Activity and Object to drop list of Stereotype 'Applies To' field
