Author Topic: How to add a package  (Read 3663 times)
Anna
« on: September 18, 2008, 02:58:29 am »
hi,
i have a problem again. This time i'm trying to add a package to an existing package.
When i first try to add the package, i get an error message "automation error", in the second try i get the message again and EA crashes. I think it's just funny, that for all that the new package is in die Project Browser. So i think it works, but i don't like EA crashing all the time.
Any suggestions would be nice.
Sub AddPackage()
'the boring part
    Dim rep As EA.repository
    Dim pack As EA.package, subpack As EA.package
    Dim dia As EA.Diagram
    Set rep = GetObject(, "EA.App").repository
    Set pack = rep.GetPackageByID(50)
'the interesting part
    Set subpack = pack.Packages.AddNew("SubPack", "Nothing")
    If Not subpack.Update() Then 'this line causes the error
        MsgBox "error"
    Else
        pack.Packages.Refresh
    End If
End Sub
Update:
I just tested the code sample "Add and Manage Packages" and EA also crashes. Is it possible that it's not my fault?
« Last Edit: September 18, 2008, 03:28:35 am by Anna »
Frank Horn
Re: How to add a package
« Reply #1 on: September 18, 2008, 04:15:31 am »
Nobody's fault but Sparx's:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1218908028
So if you're using build 832 and badly need to add packages via automation, you can either wait for 833 or downgrade to 831.
Anna
« Reply #2 on: September 23, 2008, 10:42:59 pm »
Thanks, the downgrade helped a lot.
