Author Topic: See attributes in search result table  (Read 3070 times)
floerio
« on: October 28, 2009, 01:38:42 am »
Hi!
Maybe I've missed a thing: But how can I see in the result table of the search dialog not only classes but the attributes?
I am searching for attributes that have a special stereotype. The search result lists only the classes that contain the attributes, but not the attributes themself.
Is there a way to configure this view?
Cheers,
   Oliver
Re: See attributes in search result table
« Reply #1 on: October 28, 2009, 08:57:07 pm »
Oliver,
AFAIK the default searches don't allow this.
You can however write your own sql search that shows attributes and/or operations.
Example:
select o.ea_guid as CLASSGUID,'Operation' as CLASSTYPE,o.name as Name,p.Type as 'Type',  class.name as 'Class Name'
,package.name as 'Package Name',package_p1.name as 'Package level -1',package_p2.name as 'Package level -2',package_p3.name as 'Package level -3'
from t_operation as o
join t_operationparams as p on (o.operationID = p.operationID)
join t_object as class on (o.object_id = class.object_id)
join t_package as package on (class.package_id = package.package_id)
left join t_package as package_p1 on (package_p1.package_id = package.parent_id)
left join t_package as package_p2 on (package_p2.package_id = package_p1.parent_id)
left join t_package as package_p3 on (package_p3.package_id = package_p2.parent_id)
where p.type like '<Search Term>'
union
select a.ea_guid as CLASSGUID,'Attribute' as CLASSTYPE,a.name as Name, a.Type as 'Type',  class.name as 'Class Name'
,package.name as 'Package Name' ,package_p1.name as 'Package level -1',package_p2.name as 'Package level -2',package_p3.name as 'Package level -3'
from t_attribute as a
join t_object as class on (a.object_id = class.object_id)
where a.Type like '<Search Term>'
PS. This example only works on SQL-server. If you want it to work on a local eap file you'll have to adjust the sql to the "MS Access syntax".
floerio
« Reply #2 on: October 28, 2009, 09:43:59 pm »
Hi Geert,
thanks for the script!
I did not thought that it was that kind of complex. So I would have to change the script each time my search changes...
Would be nice if the EA guys could add some dynamic to the view itself...
Oliver
« Reply #3 on: October 28, 2009, 09:50:47 pm »
Oliver,
The example is complex because that's what I needed.
If you need to be able to search all attributes with a certain stereotype that will be a lot simpler.
I don't know what you mean by rewrite when the search changes, but you'll only need to rewrite if you are searching a different field, not if you are searching for another value.
The <Search Term> text will be replaced by EA with whatever you put in the search field.
