Author Topic: Default size of diagrams in RTF documents ...  (Read 4034 times)
meierch
  • Modeling we can!
« on: October 31, 2009, 10:47:23 pm »
The diagrams are always scaled to use the full page width when I generate RTF documents. Is there an option to specify a default size?
Regards
Christian
Dave.B
Re: Default size of diagrams in RTF documents ...
« Reply #1 on: November 02, 2009, 10:55:15 pm »
Not as far as I have found, but in order to work around pagination problems the trick I use is to set the top and bottom margin in the report template to be larger than required and then when I import it into MS Word I set them back to normal. EA appears to use a scale to fit method up to 100% of diagram size.
I'd also like to be able to control which way it rotates the image, when the "rotate" RTF report option is set on the diagram properties. The convention that it uses is the opposite of the one we would normally use!
hope this helps
Dave B.
