Author Topic: Anybody help?  (Read 3774 times)
John Brand
Anybody help?
« on: November 03, 2009, 12:22:49 am »
DAO Error 3049 Can't open database <name>.
DAO Error 3049 Can't open database <name>. It may not be a database that your application recognizes, or the file may be corrupt.
· If the specified database is a Microsoft Jet database, it is corrupted. You should attempt to repair the database. If the database can't be repaired, restore the database from a backup copy, or create a new database.
Damaged databases are usually caused by power outages or network problems. To repair damaged databases run the "RTO Pro Compress and Repair Data" program. But first ALWAYS DO A BACKUP.
Any workarounds? Its just been updated! :'(
John Brand
Re: Anybody help?
« Reply #1 on: November 03, 2009, 01:55:12 am »
EA
DAO.Database [3049]
Cannot open database '#Temporary QueryDef#'.  It may not be a database that your application recognizes, or the file may be corrupt.
OK
Actual message and file is now corrupted??! :'(
Oliver F.
    • Karl Storz homepage
Re: Anybody help?
« Reply #2 on: November 03, 2009, 03:25:08 am »
EA
DAO.Database [3049]
OK
Try Tools->Manage .EAP file -> Repairs .EAP file.
Maybe it helps.
Good luck.
Oliver
Re: Anybody help?
« Reply #3 on: November 03, 2009, 10:52:14 am »
Maybe it helps.
Good luck.
Oliver
If Oliver's suggestion doesn't work, you file IS trashed...
Happened to me... Fortunately, I had a Vista Restore Point that saved the file 2 minutes prior to the crash...
Keep Backups!
Re: Anybody help?
« Reply #4 on: November 04, 2009, 08:39:42 am »
Just an idea that hasn't been mentioned yet.
Is it a JET 4 database, while you don't have EA set to use JET 4?  You do get an error much like this in that situation.
